Using lamp posts to charge EV’s | on ElectriciansForums
Discuss Using lamp posts to charge EV’s in the UK Electrical Forum area at ElectriciansForums.net
Welchyboy1
Nearly Esteemed
Essex
Heres one to consider, the apparent government solution to charging EV vehicles for people without a driveway is to install a dual 16A charger on each street lamp post
this will also remove the requirement or temptation to trail charging leads across the pavement and walkways from peoples homes
due to the lamp post now having an LED lamp there is spare capacity to charge peoples vehicles
Fantastic idea!
How the hell is that going to work?? Potentially 7.5KW per lamp post all night long, over entire streets!
what cabling did the use for the street furniture? Have they actually considered the load implications?
Has someone not really thought that through, or am I missing something really obvious
and just imagine the volt drop with 10 EVs all plugged into a street of lamp posts.
second thoughts, VD is irrelevant as the cable would be melted anyway.
It’s a ridiculous idea. We don’t all live in cities where the biggest car journey is to the shops and back.
My van can 100 miles a day just home to wholesaler, to job, to next job and back home.
I’d need 2 chargers, car and van... and a 3rd for visitors?
How are vans going to cover hundreds of miles with heavy loads in the delivery timescales we’ve come to expect?
What’s the likely lifespan of the battery’s in electric vehicles, and how much to replace? I bet it’s much more than the apparent savings in fuel and road tax.
It would depend on how the lamp posts are fed.
Some are a direct individual connection to the adjacent local DNO network, so could easilly handle extra load or the cable could easilly be upgraded.
Others, like where I live on a relatively new (30years old) estate have a feed looped between groups of posts then a single connection to the DNO supply, that wouldn't be able to take too much, if any extra laod, but wouldn't need to as everyone has a driveway.
Major roads are quite often grouped then the groups fed from a single cabinet with a DNO connection.
There will be several different solutions depending on the existing supply.
I think it's it's just as much using the lamp post location and running an extra supply so as not to clutter the street up as actually using the DNO supply at the post.
The Devil is in the detail, if they we are going to be paying to fit these then presumably they will also factor in the cable requirements and DNO smart load management as well.
Are street lights centrally switched or permanently live with their own photo-sensor switches? That alone might demand new cabling.
Most are permanent with photocells on top of the post.
The ones on major roads with cabinets have the photocell on the back of the cabinet or a low level post nearby.
Seems like a good idea to me. Saves the problem of people with no off street parking having to string cables across pavements.
This sort of thing will be common place in a few years. Along with probably lots of other things we haven't even thought of yet.
And when are electric cars going to be built with solar panels in the roof as standard? Needs to be happening now, and then it will reduce grid/DNO demand problems.
Fantastic idea!
You forgot that the long term is that no one owns a car. You dial up and a driverless car arrives and takes you where you want to go.
This implies car parks of cars strategically placed with power points.
depending what you pay there may be cars doing small detours to pick up people going in the same direction.
school runs will also use driverless vehicles and multi- pickups
no garages and no street parking.
Reply to Using lamp posts to charge EV’s in the UK Electrical Forum area at ElectriciansForums.net
