This installation has a very old DNO metal fuse box with a hinged lid, which may or may not open in one piece.
The DNO's meter feeds 2 x 63A MCB's in a 2 slot CU.
Can I feed a Henley block with both line connections from the 2x63A MCB's, thus using it as a local isolation switch?
The 80-100A DNO fuse should blow before the combined MCB's operate, assuming the current is split equally, which is should be.
The Henley block can then feed a normal CU.
Bit unconventional, but trying to think out of the box whilst waiting for DNO to fit local isolation?
