B
ben.l
Hi all
Just got a metrel mi3000. Was using it today to test a new cu job. But I'm confused...when I do continuity tests on a ring I can do tests on the crossed line and neutral using the plug adaptor but I can't use the plug adapter to do test on crossed earth and line!?
This means I have to open up the socket and use the probes.
Am I missing something. Is there a way of changing the setting so that it tests between line and earth?
Any thoughts? Cheers.
