using metrel mi3000 to do ring continuity test | Page 4 | on ElectriciansForums
Discuss using metrel mi3000 to do ring continuity test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I know this is an old thread, but I have an MI3000 and it does seem to be a bit daft that you can't switch the tester so that it does the R1+R2 test at a socket front using the 13A plug lead supplied with the tester. It would not have been difficult for them to provide this feature, and it would save messing with a Kewtech R2 plug (I know it's not a major thing, but it's an omission none the less). Daz
just swap the leads around ***. you stick it on continuity then only use two leads from the socket lead
Swap which leads and at which point? How does this enable you to use the 13A plug lead supplied with the tester? Daz
No need for the '***' either thanks. Daz
s, the Metrel testers do not have separate sockets for each lead ... L-L, N-N and CPC-CPC. They have a single 4-pin plug and shrouded socket. This ensures that you cannot connect test leads 'incorrectly' but also means that you have no choice but to do as I detailed above. You cannot plug each lead in separately like other manufacturers test equipment.
cant you use a different plug then?
I think it was worth reviving. It was a fair question from the OP. Daz
Reply to using metrel mi3000 to do ring continuity test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
