Using rebar as earthing. | Page 2 | on ElectriciansForums
Discuss Using rebar as earthing. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The reg. (542.2.3 (v))does say the rebar should be welded.
Does that mean it can only be used if it is planned and intended to be used as an electrode?
I've yet too see any foundation slab re-bar installation that was welded!! Probably nor has the author's of that Reg, and why it states ''Should'' and not ''Must''!! ...lol
The reg. doesn't say 'should' - that was me, sorry.
542.2.3 Suitable earth electrodes shall be used...
(v) Welded metal reinforcement of concrete (except pre-stressed concrete) embedded in the ground.
How would you connect the concrete floor to the MET?
How would you make a nice strong joint?
I guess this method would also bond the floor very well.
Great if there was livestock present, it would stop the old Udders from jittering.
In that case take the ''SHALL'' with a very large pinch of salt then!!! I've never seen foundation re-bars welded in the 40 years i've been in the industry... lol!!! They will all be tied together with thin steel wire, like they are everywhere else in the world!!!
Usually tied together with stainless steel wire.
As for connecting to it: drill into the top of a piece purposely left sticking out, tap a thread then connect with a ring crimp and a bolt, cover with grease to stop rusting. Is how I'd do it.
That's not the correct way of connecting to a Ufer earth. There are made for purpose clamps, (see Furse website) if you are using clamps rather than the preferred welded connection (exothermic or brazing) A nice covering of amalgamating tape seals and finishes the job...
Reply to Using rebar as earthing. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Is the property suitable for ASHP? There are quite a few unscrupulous salesmen promising all sorts, but without the insulation factors and large...
