I
installav
Hi Guys,
hope someone can help, I am newly qualified and on my first job on my own I have just added a spur to an existing ring, I was happy with the installation until testing.
Carried out 500v IR test between E-N and E-L and getting readings of 0.004M. The building is a large old victorian building with steel tubes run everywhere which provide the earth to all circuits therefore at the local CU there are no earth tails to remove so i cannot isolate the earth circuit from the ring i am working on, would this cause the low readings?? I tested a circuit that i hadn't even worked on and got the same readings. I verified the meter with a checkbox and the meter is spot on?
Would anyone have any ideas on what the problem may be caused by or what i could do to investigate further,
many thanks
Wayne
many thanks
Wayne
