V-Phase Unit - any reccommendations | on ElectriciansForums
Discuss V-Phase Unit - any reccommendations in the UK Electrical Forum area at ElectriciansForums.net
South West London
Hi there, anyone out there have any reccommendations on what brand of voltage optimiser to buy to install I clients property.
They regularly have 250v incoming (we have been monitoring it due to frequently blowing halogens and expensive LED bulbs).
Any advice on type/problems come across when installing would be welcome :)
I'm based in south London!
Thanks. Kelly
Contact your local DNO ... max permitted voltage to premises is 10% either side of nominal voltage 230v .....so 253v is the limit before they have to address the issue.... although a friendly chat may get results..... have you got a lot of PV installs local to you?
Not reaching 252v - max has been 250v . Already used good quality lamps, and now LEDs and these too are blowing frequently.
Spending untold amounts of money on lamps that keep blowing is already proving a waste of money.
DNO not prepared to do anything.
This is last option as I see it...
Good Morning
Please contact us if you have any queries about our product.
We are keen to discuss and iron out any issues discussed and we also now have a new range of products available that you may be interested in.
You can call us on 0845 003 8235 or if you provide us with contact details we can get in touch.
All of our literature is also available for download : Information & Downloads ? Vphase
Kind Regards
VPhase
Reply to V-Phase Unit - any reccommendations in the UK Electrical Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
