van led strip lighting | Page 2 | on ElectriciansForums
Discuss van led strip lighting in the Auto Electrician Forum area at ElectriciansForums.net
Very nice mate
  • [ElectriciansForums.net] van led strip lighting
Van Lighting LED Strip Light (5050)
I have got three of these in the back of my combo and it's like day light, very good lights.
Aluminium High Power LED Strip Light - 300mm :
Just bought one, 500mm led strip light (5050 leds @ 500mA) ÂŁ36 delivered. Plenty of light!
Direct battery connection via a fuse then to a switch. From the switch to a electronic timer (Foxtam YRHF 12VDC) which switches the light on for a set period of time. This time is adjustable from 15s-30min therefore no danger of a flat battery.
Was going to use micro switches for the door but ran out of time.
Where are you going to put it? If you connect directly to the battery, which will remain on all the time unless you have a switch on the positive lead between the band and the battery. It would be better to connect the positive one of its parks or wire side marker lamps as they probably want to time it's dark outside. In this way it will turn your lights on when lights.
Hope so this will help.
Hi Lucifer - I approved your post to welcome you to the forum but don't expect too many replies to your post as this Thread is 18months old, have a check of the post date before posting in a thread :)
Strangely enough, I have just redone my van lighting.
i have put 2x 1m length in the back, one in the middle and one Meter in the cab.
its all 10.8w super bright 6000k day light.
check it out, ignore the mess!
[ElectriciansForums.net] van led strip lighting[ElectriciansForums.net] van led strip lighting
Reply to van led strip lighting in the Auto Electrician Forum area at ElectriciansForums.net
Need more ladders on the roof.
nicebutdim
N
