Varilight Dimmer max loading | Page 4 | on ElectriciansForums
Discuss Varilight Dimmer max loading in the UK Electrical Forum area at ElectriciansForums.net
SW. London
Hi, hope someone can advise. Ive just called Varilight helpline in regards to max loadings on their 300w trailing edge LED single gang dimmer. They tell me that I can have a maximum of x30 10w leds on the dimmer.
Most info out there regarding dimming LED suggests to divide the dimmers wattage by 10 to determine max number of led lamps; I put this to the guy at customer services and he says varilight dimmers are designed differently and can handle the x30 10w lamps. Can anyone confirm or reject this statement.
I never think its a good idea to load dimmers to max like this; the guy at helpline says the inrush of x 30 10w led's wont effect a 300w dimmer, im not so sure.
What about a current limiting load in series with all the LEDs? Our typical 3kW immmersion heater element will limit the inrush to 13A peak and only drop 10V - 20V when the lamps are all running. My contribution to Halloween and Guy Fawkes Night :D .
I notice you rated my comment as optimistic....Do you think one of these will do the job?https://www.downlights.co.uk/media/mconnect_uploadfiles/v/-/v-com-dimmer-instructions.pdf like someone has mentioned above.
I gave you an optimistic because its not your thread - this one, and the previous lack detail and seem to lack considered response.
I would be starting with OEM's that make LED dimmers - and not via wholesalers - by contacting them directly .......... with as many known facts as possible and asking for their input
AND warning the customer that this may not be as easy as end users often think ......
As for the V-Pro - no idea mate ........... best ask them.......... but I don't like them
The link there does state for a 400w dimmer the max number of led's is 40, but it dont state a wattage ! Supposing it means 40 x 10w, thats bang on max loading which I would not like. Also consider the reply from varilight (as someone posted earlier) to use only 75% of the dimmers load, and also consider the good practice rule of thumb of using only 10% of the dimmers capacity (as shown in my earlier post); it does make you wonder if anyone really knows (including Varilight) what they're talking about,.
Dont know how you come to a conclusion that my
Not sure how you assume my two posts lack considered response and lack detail. The OP questions are what they are, the threads end up going round the houses cause people chime in with response that veers off the path, !
Reply to Varilight Dimmer max loading in the UK Electrical Forum area at ElectriciansForums.net
