Vauxhall Combo 2014 Brake lights not illuminating. | on ElectriciansForums
Discuss Vauxhall Combo 2014 Brake lights not illuminating. in the Auto Electrician Forum area at ElectriciansForums.net
LewisM
Luton
Hello somebody has just pointed out to me that none of the rear brake lights on my Vauxhall Combo are working, I will have a look tomorrow, I'm going to check the fuse and then the brake light switch, any of you guys with more experience recommend elsewhere to look?
Thanks Lewis
Thanks Lewis
Sometimes you just have to check the obvious first!
Although it might seem impossible it is possible that both bulbs are open circuit and need renewing. I'd check them first.
Yeah I might try that there are three, and when one blew before it came up with a warning light on the dash, which I didn't think the can would have
Reply to Vauxhall Combo 2014 Brake lights not illuminating. in the Auto Electrician Forum area at ElectriciansForums.net
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The...
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
