Vehicle battery as a power source | on ElectriciansForums
Discuss Vehicle battery as a power source in the UK Electrical Forum area at ElectriciansForums.net
Lincolnshire
If I use a vehicle battery connected to jumper cables, which is then connected to the heating element of a kettle, which is then placed in play sand, in a metal container, will the sand then heat up?
yes.
assuming it is a normal uk kettle it is normally 2 to 3kw at 230v
assuming it is 3kw
3000 / 230 x 12 =150watts
so it would warm the sand but not very quickly as it will only give out 1/20th of its normal power output as it is being run at 1/20th of its normal voltage.
yes.
assuming it is 3kw
I was thinking 150W is still a lump of power
Using online calculator Watts to Heat Calculator - https://www.omnicalculator.com/physics/watts-to-heat
To heat 1Kg of sand by 10 DegC with 150W will take just under 1 minute (still sounds unlikely - mistake?)
I suspect the thermal conductivity of sand is not great, so it might ultimately get quite hot.
Whereas 1Kg (1L) of water with the same 150W would take nearly 5 minutes to rise 10 DegC!
I hope the mention of 'play sand' doesn't suggest it might be played with, as I suspect this could ultimately get dangerously hot in the vicinity of the element?
I don't think it is a mistake, would not be surprised if sand has a specific heat capacity of 0.2 x that of water.
Reply to Vehicle battery as a power source in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
Absolute legend, thank you for very much for your input mate, this is really helpful 👌
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
