Vehicle battery as a power source | Page 2 | on ElectriciansForums
Discuss Vehicle battery as a power source in the UK Electrical Forum area at ElectriciansForums.net
Warning: Don’t run the fuel tank dry when the heating element is turned on!​
Fixed the link now.
It’s 300w 12v
Instead of sand, fill the box with water.
Much lighter to carry home, although it is still heavy to carry it there.
I think it's going to depend on how large and hot the heat source needs to be for detection.
Absolutely, if your trying to imitate a head sticking out of a trench, 10w in a 5 litre tin is fine, maybe a little bit too much.
If your trying to imitate a tank, 5000w is probably about right, maybe even a bit too small.
yes.
assuming it is a normal uk kettle it is normally 2 to 3kw at 230v
assuming it is 3kw
3000 / 230 x 12 =150watts
so it would warm the sand but not very quickly as it will only give out 1/20th of its normal power output as it is being run at 1/20th of its normal voltage.
P= (V*V)/R so the element resistance is 3000=(230*230)/R R=17.6 ohms, at 12V this will dissiapte 8W... as the current is 0.68A at 12V
If you want something that is safe and less hassle than the kettle then try someihing like Arcol, 27Ω 25W Aluminium Chassis Mount Resistor HS25F 27R F ±1% | RS - https://uk.rs-online.com/web/p/chassis-mount-resistors/1860145?gb=s this will dissupate 5W, the same kind of heat as a sidelamp on a car and comes with wires ready attached. get it bolted to a small bit of metal say a couple of inches across after a few minutres I would expect a decent themal night site to see it from miles! To make 12V batteries safe you must have an inline fuse such as H7335 | iMaXX Fuse Holder | RS - https://uk.rs-online.com/web/p/fuse-holders/2884498 (holder) and a fuse such as 0287003.PXCN | Littelfuse 3A Purple Blade Car Fuse, 32V dc | RS - https://uk.rs-online.com/web/p/car-fuses/7874142 If you short out a car battery it will melt the offending item, probably cause a fire and the car battery may explode. RS have trade counters across the country and also do mail order.
Reply to Vehicle battery as a power source in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! ⚡ Please note that all EV Chargers and...
    • Friendly
Absolute legend, thank you for very much for your input mate, this is really helpful 👌
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
