Hi All
After a bit of help if poss.
I recently had a new boiler installed and during the removal of the old water cylinder the plumber ripped out feed for the alarm system by "accident" and now it is not working at all. I put in a new t+e and have disconnected the battery and mains and then put back together but nothing changes. The red tamper light is constant on the keypads and also the green is constant above it for unset. It randomly went off last night before I put new feed in and there was no mains power and our code would not work, so ended up taking cover off and removing power supply fuse. I have tried the eng codes 4321 and 1234 but nothing changes state.
Does anyone one have any other possible solutions.......
thanks
chris
thanks
chris
