Discuss Vertical Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
Its a 3.5 bed/ 1 living room/1 bath/kitchen/1Wc house.What is this consumer unit supplying? Approx building size / use? I'm thinking it is perhaps a very large house with a 3-phase 200A supply, or maybe something else?
I think you are probably right! thanks for all your adviceThere's either going to be some heavy equipment in there or the builder hasn't got a clue.
I suspect the latter.
So it is 200A at the moment! There are two main switches and two RCDs of 80A each plus additional MCBs separate from those.
I think the builder's electrician has looked at it and confirmed it cant fit in the space available. I wanrt to make sure that isnt just a cop out. Also, SPN have said that the incoming cable cant be adjacent to a boiler..news to me.Then you have a problem, and a really bad electrical design.
If the supply is 200A then the main switch needs to be rated for at least 200A as do those RCDs unless they have some form of 80A protection before them.
If the installation really needs 200A then 2x 80A RCD’s will be no good as that would only allow 160A!
Plus DNOs don't provide single phase supplies greater than 100A to domestic properties (not sure they will ever provide more than 100A SP) so the supply must be 3 phase, in which case you'll be having a much bigger consumer unit than anything you've seen in a regular house.
Have you actually had an electrician look at this?
Reply to Vertical Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
