After adding a SFCU as a spur off a kitchen ring circuit I took a direct Zs reading which was 18.4 ohms / 13A. When I then checked from main incomming tails I took a reading of 17.89 ohms / 13A. Rcd trip tests work fine and within required times etc.
As this is a very high Zs, what should I do ref issue of minor works for the work I have done. i.e note on cert of problem or is there something I should do to rectify first.
