Very old fuseboard change | on ElectriciansForums
Discuss Very old fuseboard change in the Electrician Talk | All Countries area at ElectriciansForums.net
Ok then,
Got a 15 way 3phase board (re-wirable) to re-locate and change to a new one. It's a really old BILL one from years back. Its a weekends work for 2 blokes. Just a couple of things I wanna clear up.... :-
1. Im going to put RCBO's in for anything that has a socket outlet on it, 3phase or single phase. I'm pretty sure it doesnt need to be loaded full of RCBO's for every circuit??
2. What is the best way of sequencing the neutrals respective of the correct circuits i.e. what is the best way to find out which one is which without tracing them and not blowing up machines.
Your help will be muchly appreciated
Cheers
It realy depends on the installation method of the other circuits and also what the other circuits are supplying , one thing i would do before you change the board is to inspect the installations , you could open a large can of worms with a board that size and age ,
Imo Nick speaks great sence Can of worms before DB change of this size as you never know who had done what and what has been swapped around a right good PIR to identify circuits
Reply to Very old fuseboard change in the Electrician Talk | All Countries area at ElectriciansForums.net
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
