A
amckay
my mum has an ex council house shes had for years, the tennant has finally gone and its time to sort the gaf out and she asked me to check out t'lectrix.
im really unsure about this one. there is a very short spur from the 3036 board to a single socket outlet ( 3inches below board) and pluged in is what appears to be a 12v plug which has been wired directly to a 6mm cable (earth coloured) which then goes directly into the wall cavity, from there untraceable. the plug actually says do not disconnect.
Has anyone come accros this in social housing / council rewires and know what it might be at all? im baffled by it.
im sure if i turn power off only leaving the said cable on i could trace it with non contact volt detector but im too lazy.
see picture if that helps.
and thanks guys
and thanks guys
