Vintage Lamp CPC suggestions please | on ElectriciansForums
Discuss Vintage Lamp CPC suggestions please in the Lighting Forum area at ElectriciansForums.net
Wilko
V.Nearly Esteemed
Berkshire
Hi - been to fix a lamp today with a loose connection in the lovely terminal blocks. Then I noticed there's a brass lamp holder with no earth terminal and the earth is cut back in the wall. There's 4 of these fittings (8 lamps) in the room and they're probably all the same. Any suggestions for a fix would be most welcome :) .
[ElectriciansForums.net] Vintage Lamp CPC suggestions please
New brass lamp holders with cpc terminals and rewire i guess :( unless you can find bakerlite type ones that the fake candle wax sleeve will fit over
Possible that may do it Kev as the thread aperture looks bigger than the 10mm, 1/2 inch you normally get pity it doesn't say.
I see that there are two cables behind that lamp.
No cpc continuity then!
Reply to Vintage Lamp CPC suggestions please in the Lighting Forum area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
