virtual earth | on ElectriciansForums
Discuss virtual earth in the UK Electrical Forum area at ElectriciansForums.net
daiplayer
Any body got some input on this?
Was talking to a guy that said he used this in domestic fault finding earth faults.
He ( where i would normally take an hr or so ) managed to locate and isolate a ring fault in ten mins. .
Any ideas?
The only virtual earth i know of exists in a virtual world where every sparks living there can only earn thier 'Qaulified' status after 3 or more years of onsite experience along with technical training.....
:wheelchair:
Clues in the title . ..........
Found this :-
The virtual ground concept aids circuit analysis in operational amplifier and other circuits and provides useful practical circuit effects that would be difficult to achieve in other ways. An ideal virtual ground would be able to source/sink an infinite amount of current. In practice, the sourcing/sinking capability is determined by the other circuit impedances and the amplifier used.
How to create a virtual ground point:
Since an operational amplifier has very high open loop gain, in negative feedback circuits the amplifier acts automatically to make the potential difference between its inputs tend to zero. Consider the simple inverting configuration below. If the non-inverting (+) input of the operational amplifier is grounded, then its inverting (-) input, although not connected to ground, will assume a similar potential, becoming a virtual ground.
me too , but it amazed me how he did something or other, did a few tests ( loop testing i think ) , and found the fault in literally under ten minutes . i wanna know how he did it ! lol
It sounds like it could have potential, if saving time is important to you. Sometimes it can be good if a job takes a while though, especially when you don't have any more lined up! :)
Reply to virtual earth in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
