Visual check to determine tnc-s or tns | on ElectriciansForums
Discuss Visual check to determine tnc-s or tns in the Australia area at ElectriciansForums.net
R
Robo
Is it always possible to determine between tnc-s and tns by visual inspection. Tnc s is obviously combined N and E in the dno cut out and earth come from inside cutout.
If it was a tns would the earth always be clamped to the lead sheath of the cable. Thanks
Today i saw a dno and i could just see through the base where cable entered. I could see un sheathed swa which went inside cutout. Is ther any chance this could have been a tns. seperate core for each L and N and swa for earth??
Or is a tns earth always clamped to outside of cable armour before in enters cutout??
Or would this have been a split con Tnc - s .
yesterday i saw a 16mm earthing conductor to a bs951 clamped to supply sheath then a un-insulated swa to the terminalson the cutout for the connection terminal to make it TN-C-S
its a council house which has had a PIR done august last year so is this a TN-C-S or A TN-S lol or both I know the BS951 is a no no and the DNO need to sort ot as its there mess
no grommets where cables enter enclosure metal clad ccu 2 knockouts trunking with no lid shower IP4Xnot maintained , RCD tripping and wont hold in even with all loads and CBs off this is why i went round as its one of our friends and she was cooking tea was working then just tripped and that was that as it was Council and i wasnt getting paid told them to get council elecys out
they came tested and confirmed after 2 hrs it was the rcd they installed a double socket to one of the 2 ways working on the other side of the split load board which are both the up and down lighting circuits both 6A type Bs
these are all NICEIC contractors
I would go with ENGINEER as this is my opinion also he is spot on
[ElectriciansForums.net] Visual check to determine tnc-s or tns
As widdler's diagram shows, if the property is supplied with splitcon then it is not possible to visually check unless you remove the cover of the cut-out. My old house was supplied in split con and to the untrained looked just like a TNCS supply.
i also had a property with what seemed to be tncs and tns. it had the earth coming from the sheath as well as the cut out so its not always possible just by a visual as to which one it is.
Never personally seen a cut out box like the one shown, ....we live and learn!!! I would still say however that in the majority of cases, you would be able to visually determine the earthing arrangement of the DNOs supply...
If you were ever unsure, then a Ze test would soon determine/confirm as one or the other...
Reply to Visual check to determine tnc-s or tns in the Australia area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
