Visual check to determine tnc-s or tns
R
Robo
Is it always possible to determine between tnc-s and tns by visual inspection. Tnc s is obviously combined N and E in the dno cut out and earth come from inside cutout.
If it was a tns would the earth always be clamped to the lead sheath of the cable. Thanks
Never personally seen a cut out box like the one shown, ....we live and learn!!! I would still say however that in the majority of cases, you would be able to visually determine the earthing arrangement of the DNOs supply...
If you were ever unsure, then a Ze test would soon determine/confirm as one or the other...
You still can visually, you just have to remove the cover (no testing required).
I had a 100A DP isolator fitted by british gas (unitied utilities) at my brothers so i can replace the two existing boards and tails , new digi meter
when i looked at the supply It has 2 supply cables I asked the meter guy was i TNS or TN-C-S
he said it was a TN-C-S but when i tested PEFC I got 2.5kA and PSCC 3.9kA on one board and on the other i got a higher PSCC of 4kA they are both fed from henley blocks which are in turn fed from the same supply
so if its TN-C-S then why the higher reading is it as i suspect that its because it has two supply cables not sure which is doing what
It probably had two supply cables because it was a looped supply, so one of the cables would be supplying the next property.
Hi mate cheers but thought looped supplies only happened on old terraced houses this is a semi detached and there is a drive and garage between both properties and thats the side the supply is
if it was a looped supply it would be on the other side i think the side that has the party wall I will post a pic if i can
sorry its not a good pic was took a while ago of my old phone i have a newer clearer picture
Just depends on how the DNO has wired there supply, seen detached executive houses loop wired in the Kent area. In this day and age it saves them money on joints and labour costs ... same old story throughout the industry really i guess ....Cost Cutting Rules!!!
thanks engineer one of the cables is slightly larger than the other
how could i determine if its a looped supply without interfering with there equipment as they say we cant unless the seals fall out which is highly unlikely as they have just fit the isolator and tails to there side
the only place they havnt fitted seals now is the load side of the new 100A wylex D.P. i tried to look as he was doing it but its in a cupboard under the stairs soi couldnt get a good view
cheers suppose i will just have to take there word for it
the Ze was 0.09ohm and the pefc 2.5kA and the PSCC is 3.9kA on 1 board and 4kA on the other so it wouldnt have been possible to determine from measurement of the pefc or pscc if it was a TN-c-s but as we have seen in above posts that it can look like a TN-c-s but in fact is a TN-S
I am going with what the meter guy said as without taking the cover off theres no way to know for sure if its a looped supply or otherwise
