DomB
Morning chaps,
Had a query come in about the different ways VO4Home & Vphase work. VO4home works on reducing the voltage by a set amount at installation whereas vPhase reduces whatever comes in to 220V.
vPhase's website says "There is an (additional) risk with set reduction commercial systems that if the utility company reduces voltage too close to statutory limits, maybe for short periods or transient events, then the site could drop below statutory limits because of the fixed reduction of voltage. This would cause a “Brown Out” at the site. The VX1 does not suffer this problem. If the utility voltage drops below the VX1 set point then the VX1 simply enters bypass mode and the utility voltage is applied to the house."
The supply we want to optimise covers two properties (a main house and a granny flat) so the VO4Home's active rating of 60A is the right thing (v's the 20A rating of the vPhase). I just need to get past this potential brown out issue for the customer. Any thoughts?!
Thanks very much!
Thanks very much!
