A
acsparks
I'm about to upgrade consumer unit and current install has a voelcb as protection to current cu.When fitting the new duel rcd board can i use this as my isolation switch asuming i upgrade the tails to 25mm from the voelcb to the new board.If i was required to replace this then i would have to remove the main fuse and cut the seals which i don't really want to do.This is going to form part of my nic inspection so what i need to know is will they be happy with this or should i just replace the voelcb.
