J
jackofall
Good evening gents,
I am new here so will say thank you to anyone that takes the time to read this post, even if you don't reply to it.
I have been asked to look at an unusual vehicle based Mobile communications setup which uses a VOELCB for a chassis earth trip and a separate safety earth trip. This being the only main isolator.
Obviously if this was built today, it would not be up to current regulations as there is no main RCD protection, but I am being assured by the client that this was designed and built pre the regs change in 2008.
The power for the installation is supplied from an on-board generator to the skin of the vehicle which can supply up to 62A, so a fair amount of juice.
The question that I have is, if the chassis earth fails to trip, but the safety one still functions once the platform has been set up and earths applied, would the installation still be safe to use? The answer may seem simple, but am having to put up an argument over it.
Another question I have, if you are doing the yearly inspection how would you go about recording the performance of the VOELCB? R1,R2 tests can still be carried out within certain parts of the wiring, along with some trip times on RCDs within the vehicle that are supplying 13A plugs but just not sure on the main way of testing the isolation of the vehicle.
Any answers would be appreciated.
