volex rcd | on ElectriciansForums
Discuss volex rcd in the UK Electrical Forum area at ElectriciansForums.net
SPARTYKUS
hi
just a quick one,
as far as I'm aware, RCD's (with two poles, specifically the VOLEX VR80 30mA) don't care which side the Line or Neutral go in.
Am I right?
Or is this model a special case?
Can't think why, I know it works on an inbalance betwixt L-N, and the bumpf says you can wire it up either way, horizontally or vertically.
EDIT : when I say either way I mean the feed can go in the top or bottom.
Depending on how the test function has been implemented, wiring it the wrong way around could cause the test function to either not work at all or create a phase-earth fault the wrong side of the RCD which obviously isn't protected.
Edit: Scratch that. It only applies to old school devices that don't have a test coil wound on to the toroid.
Reply to volex rcd in the UK Electrical Forum area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
