is this right
mv on chosen cable from regs x length of cable run x design current of circuit
divided by 1000
is it calulated amps or the breaer your going to use
is that all as im trying to work out for this lighting circuit but to get the volt drop under 3% the cable needs to be 6mm
ta for help
Nice one,
32 metres is my last point on the ring and thats my 26A and then divide by 4 because its a ring , ie 4 off 2.5 mm cables.
So ((18 ÷ 1000) x 26A x 32M) ÷ 4 = 3.74v
Do you mean the ring is 32m from end to end or it's 32m to the mid-point. If it's the latter then your ring circuit length is 64m.
The length of the ring starts and finishes at the CU.
lockhes,
AliRaZoR,
TrueNAS JBOD Storage Server
