volt drop on elv LED wiring | on ElectriciansForums
Discuss volt drop on elv LED wiring in the UK Electrical Forum area at ElectriciansForums.net
G
Gunnspark
Hi. I'm new to LED wiring and am wondering how to work out volt drop when using 24 volt drivers and 2mm elv cable. The length of run is about 20 metres. I've read that the 4% stays the same as 230v but what would be the maximum length of cable that could be used?
There is a formula and there are reference tables however 2mm is not in any of my references. Is 2mm the outside diameter of the wire or the cross-sectional area of the conductor?
Vdrop = IR. If it is a 2mm CSA wire you'll need to go to the manufacturers website to get the resistance per meter.
*Edit* For apporximate reference purposes 2mm CSA is pretty close to 14AWG size.
Maybe we should go back to the start. You want to work out the volt drop across the wiring (2mmCSA) between an ELV (24v) LED driver and the load ie the LED lamps? Is that correct?
If the driver is a constant current type then volt drop doesn't really matter as long as the LED gets the right current.
Reply to volt drop on elv LED wiring in the UK Electrical Forum area at ElectriciansForums.net
That's brilliant Dave, thanks again. I had to raid my sons felt tips and pencils for any colours available! Apologies for the strange and...
4K
Recommended Sponsor News
Hi everyone,
