Volt drop, why do we bother? | on ElectriciansForums
Discuss Volt drop, why do we bother? in the UK Electrical Forum area at ElectriciansForums.net
South east
Looking at the regs it says we have a supply of 230 Volts and so we do our calculations based on this so that if we had to install lights on the end of a long cable we would use a cable with a larger CSA and hence more cost.
The fact of the matter is we have a supply of 240 Volts so why do we bother?
What is the point of installing these larger cables when there is no need for them, no need at all?
Thanks for reading.
Having a voltage drop higher than 3% is not necessarily a safety concern, but rather a performance concern.
In the appropriate circumstances, finding out voltage drop is a wise first step because low voltage has many negative consequences, such as wasted energy in the wiring system. Wasted power is commonly followed by poor operation of electrical equipment, among other problems.
Determining voltage drop is essential, since not doing so could be detrimental to the life of your equipment.
Dichroic
Dichroic
not just that....you might find stuff not working at all....lamps not striking etc....
Whilst supplies are now currently running at 240 v, the DNO's are in the process or should be of improving and stabilising the supply voltages to 230 v +or - the accepted variations. Unfortunately we have to design circuits to the guidelines presented, therefore all our calculations are based on an agreed supply voltage of 230 v
Yes it was agreed some time ago, but as yet still has a long way to go, just like the requirements for making all TN-C-S installs PME, its going to take time, but we poor electricians have to do our job when clearly the DNO's are lacking in their duties.
Reply to Volt drop, why do we bother? in the UK Electrical Forum area at ElectriciansForums.net
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
These are questions to complicated for a simple answer It depends on many things Cable size Cable length Load type and current Filtering and...
