volt free contact inside electric heating boiler | Page 4 | on ElectriciansForums
Discuss volt free contact inside electric heating boiler in the UK Electrical Forum area at ElectriciansForums.net
K
Kev2632
http://www.electric-heatingcompany....0/03/electric-boilers-tech-install-manual.pdf
Go down to page 8 of this document, you will see it asks for the contacts to fire the boiler up to be volt free, now i do finally understand i think what this means, it means that those two contacts R+P are independently volt free from the power being supplied to boiler, now what i cant understand with the way the booklet is telling you to wire the boiler up is, when wiring a normal 2x 2port valve set up, we supply either the orange or grey with 240 and the micro switch closes sending 240v down the other core, how can this boiler work when there will be no voltage at all applied to either orange or grey cores?? and is it possilbe to feed 240 volts onto one side of the R+P volt free contact at all ? and have 240 come out the side of either R+P ??
thanks again guys
was there a way to get 240 switch live (interested incase it comes up for me)
(Not required in this case but) yes, there is.
You wire it as the manufacturer states in the installation diagram.
If it requires 240V then it will receive 240V.
Google images - S plan or Y plan wiring diagrams - other methods will probably appear as well.
Reply to volt free contact inside electric heating boiler in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
