Volt Stick Tip. | Page 2 | on ElectriciansForums
Discuss Volt Stick Tip. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I cant believe so many people have negative views about these, they are brillaint and save a lot of time to verify circuits and avoid removing accessory plate's untill you need to. Imaging your in a 5 storey office block testing a 36 way landlords board with no circuit chart or any details, you can not unscrew every spur and put it back till you find the circuit your after. They save heaps of time and help get the job done quicker. A great bit of kit!
If its a socket I know a few guys that trip the breaker using a plug top and then see which mcb has tripped
I have found a very good use for them...I've taught my 4 year old & my 6 year old daughter that there is 'lectric' in cables and sockets. Excellent way of teaching them about the dangers of 'lectric' because it lights up and it beeps
Thats nuts doing it like that, they could cause a lot more problems for them selves.
Or you can use a socket N see tester with audible noise and switch of the circuits one at a time till it goes quite, and if its really far use walkie talkies so your not walking back n forth or up flights of stairs.
Not always practical.
For example in one place my mate searched high and low and couldn't find the db at all.
followed where the board was fed from and could see where the swa went down but nothing on floor below
In the end It was hidden in wall behind a sheet of ply screwed to wall then painted over. (Even the owner didnt know it was there)
Saves loads of time at christmas finding the blown lamps on the tree lights although LED's are taking over now
as you say great piece of kit , use mine everyday , mine has a tone alert so i stick it on the circuit , place my 2 way radio next to it with the button taped on and stand at the db 50 metres away and start flicking breakers till it goes off :) , as long as your not using it to prove the circuit is dead whats the big deal about using them
Reply to Volt Stick Tip. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
View: https://www.youtube.com/watch?v=t1TcDHrkQYg
Crikey, is that the time???!!! I must get some sleep soon as I have a busy day ahead, and looking forward to working alongside a forum member...
