volt stick | on ElectriciansForums
Discuss volt stick in the Electrical Tools and Products area at ElectriciansForums.net
Bath
Ok i know some people dont like them and i know they should not be relied on but i find they have there uses especially for fault finding
My old RS one has just broke, i have tried a couple of others and they dont seam as good.
So does any one have any recommendations
Yep my main work is fault finding and it comes in handy but and i say but I dont trust it as far as i can throw it so I always test it on a known live source and if I have to dimantle anything then the tester comes out .
One example today tenant had a faulty lampholder on a pendant plus 2 table lights not working traced to 2 dud 3 amp fuses no tester brought out just used the volt stick so in this case a big time saver
use the fluke pro230. this has a fork in the end so that it has to have a live cable in the forek to light up. very useful in a bunch of cables.
I use a Fluke VoltAlert 1 AC-E II. It works great, but it hasn't got a fork in the end.
Of course voltsticks shouldn't be relied on for safe isolation, but they have their uses.
I carry a pair of snips 100% effective at detecting live wires!!!!!! and usually have the added bonus of tripping the circuit without need to trace it.
Yeh, but they have got to be a brand new pair, when they get old and blunt you never find live cables with them...
When I'm trying to identify which circuit to switch off I like to hear or see the effect of turning off a circuit breaker or isolating switch. For sockets I use a Martindale BZ101 Buzz It. For other circuits I sometimes wedge a voltstick (can't remember which make and it's out in the van) against the cable and listen, but it's a bit quiet. Does anyone know of one of these things with a good loud buzz or whistle which doesn't need a button holding in for it to work?
Reply to volt stick in the Electrical Tools and Products area at ElectriciansForums.net
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
