Volt sticks and what is you opinion | on ElectriciansForums
Discuss Volt sticks and what is you opinion in the Electrical Tools and Products area at ElectriciansForums.net
I find that a volt stick,is ideal for using as a pointer in the suppliers,as in "Pass me one of them...no next to it...no,the other side....that's it...that AVI..." ;)
Wouldn’t trust them to prove something’s dead, but I find them useful to locate and verify circuits particularly where you can’t use a martindale or where FCUs don’t have neons, and you don’t have to unscrew fronts to get at the terminals.
Also handy for identifying a cable you need to trace, again no need to make contact with the wire.
I don’t currently own one but have used one for identifying a cable in a loft that I wanted to ‘tap into’ I think it was to run a tv amplifier,
if you have ever shopped with testermans and sign up to the newsletter they will give you a free voltstick.. which tells you all you need to know! on the positive side the used and reconditioned testing kit on the website is quite well priced.
Can be handing for fault finding when tracing out conductors etc and for stirring my brew...
No good for stabbing apprentices with though, not sharp enough...
Tap/stroke some models rhythmically ,and you can pretend something is dangerous , even with the power off.
--BEST keep you fingers out-of here--
Red Light means danger.
All that capacitance -stuff is dangerous..
(..they can tell lies.. as we all know)
got one with my clamp meter thrown in the box, even my weetabix makes it glow! found out when i put it on the side with the shopping next to it!
Good blunt force trauma though a well placed dig between the ribs could be effective;) joking of courseo_O
Although these items get a bit of stick :rolleyes: they do find a use.
I have some,somewhere, i think,if my 10 year old hasn't used them as a tiny light-sabre...
I do use the volt-sense end of one of my Megger devices,330 maybe? So,a large,glorified stick of sorts ;)As ever,used appropriately,even an elastic band is a suitable tool...
Reply to Volt sticks and what is you opinion in the Electrical Tools and Products area at ElectriciansForums.net
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
