Volt sticks and what is you opinion | Page 2 | on ElectriciansForums
Discuss Volt sticks and what is you opinion in the Electrical Tools and Products area at ElectriciansForums.net
I used one the other day as I was extending a lighting circuit and located two cables going to the rose to tap off of. Volt stick was very handy. Disconnected the feed at the rose and parted the cables the volt stick told me which one was live/feed as I could not get directly above the rose downstairs this was very handy. As to relying on them for safe isolation, when hell freezes over!
As already said - I wouldn't use for 100% isolation but they have uses. Except the Megger one I have which is so sensitive. I think that one would chirp if you put it near a watch battery.
An absolutely useless way to get yourself hurt
Totally disagree with you there.
It's an absolutely ideal way to get yourself hurt.
You may as well pick up a stick in the forest and use that to ensure safe isolation. Just as safe.
On second thoughts you may get a splinter in your pinky from the stick.
They might tell you there is current, but I wouldn't trust one to confirm there is NO current..so, useful at times, but not a life-saver.
I don't have one and don't want one, nor a neon screwdriver for that matter. Although nearly everyone on here understands safe isolation and the reason they should not be used, reality is, like in any job, short cuts and complacency do set in when carrying out the same tasks regularly and reality is people do rely on them for a quick answer that's "probably" correct. No different to an experienced driver knowingly not driving how they would if they were taking a driving test.
Issued by dno as polarity tester. That is the only use, after a circuit is proved live or dead by test lamps. Definitely not to prove dead
Put one in your top pocket of your boiler suit and everyone on site looks at you in awe as you are the master electrical engineer, you also need a few pens and a moleskin notepad to really pull off the look......
To all those who are uninformed - a moleskin notepad is a Brand and not the result of the ‘patient trapping’ in order to clothe one’s pages with softness!
Reply to Volt sticks and what is you opinion in the Electrical Tools and Products area at ElectriciansForums.net
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
