Voltage / Continuity Testers - feedback required | on ElectriciansForums
Discuss Voltage / Continuity Testers - feedback required in the Electrical Tools and Products area at ElectriciansForums.net
G
Guest55
Noon all ,
I need a new set of Voltage / Continuity test probes and was wondering if anyone has had probs
with their testers tripping out rcd's / rcbo's whilst measuring voltage ??
If so please name and shame so i can avoid.
Any other input on whats good or bad is also welcome.
Quite like the look of these , metrel digi testers , anyone use them ?
[ElectriciansForums.net] Voltage / Continuity  Testers  - feedback required
The ones with LEDs they all trip the RCD. I have a really oldfashioned one with neons ( relic from the seventies) it doesn't trip the RCD.
my Di-Log doesn't trip the RCD. it's the DL6780. in hindsight i wish i had got the DL6790 which has a LCD display, handy for checking LV transformers, meauring resistances etc without having to get the MFT out. the only reason i decided not to get one with an LCD display is because i was told that if i had one with an LCD display then it would need calibrated every year like my MFT...
^^^ yeah , i definately prefer a lcd readout with actual numbers , cant be arsed decifering flashing leds.
good work men , keep the comments coming.
as for calibrating , i wont bother with voltage testers , they're just for day to day jobbing , i've got a fluke for the super accurate measurements.
i like the fluke T5, as it's also got an open jaw clamp meter. very useful.
would you believe i was given one as free issue whilst working for county council.
excellent unit but it stopped reading dc voltage after a few years ( which i need for auto electrics ) so i gave it away to a collegue who had his tools robbed.
Reply to Voltage / Continuity Testers - feedback required in the Electrical Tools and Products area at ElectriciansForums.net
I have the Kewtech that I bought in an emergency when my trusty Fluke that lasted many years gave up. It works! It has single pole testing too btw...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
