OP
Guest55
I've 2 sets of the Megger units. Very good testers
so your budget wasnt £40-50 then ?
Discuss Voltage / Continuity Testers - feedback required in the Electrical Tools and Products area at ElectriciansForums.net
LOL, nope, both sets were free. So below the budget mentionedso your budget wasnt £40-50 then ?
[FONT=&]If you are not interested in the LED or lamp indication Biff, but prefer a meter, then why buy a 2-pole voltage tester at all. HSE, GS38 only advises that the use of an approved 2-pole voltage detector for determining the presence or absence of voltage (proving dead) is the preferred method. Therefore there is nothing to stop you doing safe-isolation (proving dead), like any other voltage measurement, with a GS38 compliant MFT on the voltage range, it's just not best practice (ESC, BPG2), and you need to ensure that only a voltage range is selected for safety.
Note:- Approved voltage testers (AVT) that indicate voltage in broad bands do not require calibrating. If the AVT incorporates a meter it requires annual calibration, like any other meter, to assure accuracy.[/FONT]
http://www.hse.gov.uk/pubns/priced/gs38.pdf
http://www.esc.org.uk/fileadmin/user_upload/documents/industry/best_practice/BPG2_09.pdf
My Fluke T100 will trip RCD's according to the order you test L-N / L-E, you can get them for £32 if I shop around.
I briefly owned a Metrel but it got sent back due to parts missing, very poor build quality, Metrels name didn't appear on anywhere, both sides of the casing were a completely different shade and they managed to spell 'safety' wrong on the packaging. I contacted Metrel as I though it was a cheap copy, but they confirmed it was made by them!
Reply to Voltage / Continuity Testers - feedback required in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
