Sort of. As I can't get values for 5mm cable but work out estimated it's about right. Take voltage drop as 8.5 and Ib 30amps it is roughly 90m.
Why mess about trying to make up formulae when you have been given the correct ones in post #2
Discuss Voltage drop question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So "4" is there because you calculate VD on one leg (length/2) and as one leg has half of the load ( Ib/2) ?
light on a ring?
Reply to Voltage drop question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
