Why all the complicated formulea for working out voltage drop?
Why not just connect the load and measure the voltage with a meter?
Discuss Voltage Drop in the Australia area at ElectriciansForums.net
So what happens when you have installed the new circuit etc etc infront of the customer and then when you connect the load find the voltage drop is to much so infornt of the customer you have to remove the incorrect cable and put in the next size up just to find out thats wrong as well. Need I say more.
Chris
Reply to Voltage Drop in the Australia area at ElectriciansForums.net
