Voltage dropping in a domestic house as you use more appliances ? | on ElectriciansForums
Discuss Voltage dropping in a domestic house as you use more appliances ? in the Domestic Electrician Forum area at ElectriciansForums.net
B
Bern1e
Hi folks!
Any answers on this problem?
I attended site and was told various items of equipment caused the rcd to trip randomly,after checking the Ze and voltage I tested the rcd which wouldn't trip x1 or x5.
I then deemed this faulty and replaced the rcd only to find this also did not trip.
I then decided my tester might not be working so i used another and the same problem occurred,by this point I am pulling my hair out.
After testing the supply voltage I noticed that when more appliances were plugged in the voltage decreased.
It was also noted the rcd would test on the incoming supply cables end but not the busbar side.
I m now deciding t become a brick layer !!!!!!!!
Help please me thinks uk power networks problem and loose neutral there endis the issue.
Ensure when you are running your bricks you have set a guide line up to keep your run level, use a good cement mixture and don't rush it until you have gained the expertise of a well seasoned brickie... hope that helps ;)
Was this site in a rural location possibly at or near the end of an overhead supply , I have seen a very similar situation where I live especially when off peak supplies are switched in. if this is what your finding then yes its UK power networks issue , what is the lowest reading your getting ...
Maybe also measure a neutral-earth voltage when it's under load and the voltage drops and take your measurements at the first available point in the premises. This might help indicate a supplier neutral issue.
Reply to Voltage dropping in a domestic house as you use more appliances ? in the Domestic Electrician Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
