Voltage on CPC | Page 2 | on ElectriciansForums
Discuss Voltage on CPC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In other words, always carry a cheap analogue voltmeter in your test kit, to check any suspected phantom voltage!!
Above my pay grade. But going back to my original post, this came to my attention because my Megger 1730 aborted ZS/RCD test because it sensed a 'high touch voltage' at that lighting point, but not at an adjacent ceiling rose (on the same circuit). So is this touch voltage, a phantom voltage, I can't see that?
Reply to Voltage on CPC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
