Voltage reading puzzle | Page 2 | on ElectriciansForums
Discuss Voltage reading puzzle in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That is my next move, just a little puzzled why this fault could occur. Never come across it before.
i always enjoy stuff like this, gives you a greater sense of satisfaction when i find the fault, unfortunately with our line of work these things occasionally crop up.
I'd be doing dead tests at different fittings!
The circuit is on two levels, my thought were to disconnect the supply that enters the loft. Then test the level below, hopefully eliminating one floor.
Hoping that the fault lies within the loft as access is easier.
Only you'll know whats easiest, did the guy only change the CU? wasnt poking around in anything else?
Hes said hes already IR tested and its clear, but im inclined to think id be doing them again!
An IR test on a circuit with a "break" on it or loose connection isn't going to tell you anything, whereas a R1 + R2, R1 + RN, R2 + RN to confirm the continuity of all conductors followed by IR would be of more use.
Yes the IRs came up brand new, I did test twice but there were people in the house, may be that a switch could have been opened then closed without my knowledge.
I did ask the question and claims not to have touched anything else, other than the CU. Which also seems to be confirmed by what the occupants are telling me.
Reply to Voltage reading puzzle in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Induced voltage can be a bit of a red herring when using DVM my guess is somethings moist.
TerryBNZ
T
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
