voltdrop calculation | Page 2 | on ElectriciansForums
Discuss voltdrop calculation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
What size cable would that result in for 60m 100A supply?
(Hint, I fell about laughing.)
One thing that has struck me, the OP is suggesting a 100A fused switch. No allowance for discrimination between a standard 100A service.
i have not suggested anything and have not done any work on this installation , just described the lay out of the existing installation which includes a switch fused 100amp isolator at the mains position.
the plot thickens.
i'm told there use to be a caravan were the new garage has been built .
found an enclosure with a consumer unit fed in 25mm SWA.
with no sign of the "Caravan supply " SWA at either end the bulder made a few calls and i was told there is an underground " tee joint " in the main SWA before the house !
anyone come across that before.
whipped the cover off the CU in the house for a quick look and has all the hall marks of a "Pub Job" ,just had a copy of the toilet paper /test sheets
box marked reg no reads "12345678 " .
due my inspection next month and jobs like this make you want tell em to shove there fee up the rusty rivet hole.
Reply to voltdrop calculation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
