Vphase units | on ElectriciansForums
Discuss Vphase units in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
thebassman
Hi All
Any of you fitted one of the Vphase units and were there any issues with it , we have a customer who wants one fitted and he is supplying it, i have downloaded the installation manual and as far as i can see you need to do some mods to CU to separate circuits. I have arranged to visit him next week to see if there is room to fit it and if the CUs can be altered as far as i remember they are older Hager Mcb board fitted around 9 years ago.
Any advice would be helpfull and any problems that you may have encountered
DAnny
I think you'll find that no-one here has much time for these basically useless, expensive over rated gizmo's. Far better to spend the cost of these units and buy Led lamps for every light fitting in the house. You'll get a better and faster return on the investment too.... lol!!!
HI
Thanks for reply yes i tend to agree just spent the last hour on there web site down loading and reading there pdfs and what i can see is they have limited current 16amp then they go into bypass, the house we have asked to install it is really big i recently did a PIR for his insurance and i just checked there is 3 CUs 2 x 15 ways at point of supply and 1 x 8 way in upper floor, there is only one spare way. Dont think he is going to save anything the cost plus our fitting and i am sure the CUs will need changed the pay back time would be very long and the units have a 5 year life so where is the saving if you need to replace it every 5 years, anyway if reducing the voltage to 220v saves money i am sure the supply companies would do this themselves. I think i will be advising against it as i dont see any point in them thanks for your reply.
I have fitted a fluorosave unit to 250w son lighting in a factory whaich after warn up period the unit changed to energy saving and if any further load was switched on it switched out of energy saving for again 8 mins, i remember taking current readings at the two stages and they was a drop of 1kw on a 4kw load this factory has reduced there bills but they also installed a 12kw 3 phase wind turbine last time i spoke to them there bills had reduced by 38%, i suppose there are ways of saving but the vphase in my opinion is not one.
Danny
The only problem I have found with me Vphase unit is someswitched mode power supplied device can produce high pitched noise. As do they work the answer is yes. Mine has stepped down the voltage from 254Vto 221V. Average household savings areover 10% with many of my appliance i have tested have reduced power consumptionby up to 24% for things like laptops andTV’s. Payback works out at 2.5 years formy house
The reason for this is because SMPS have feedback from the secondary (output) side to maintain some form of regulation for the O/P voltage, it does this by varying the Mark/Space ratio, the time the switching transistor is on to the transistors off time, if the supply voltage is lower, the switching transistor is switched on longer to maintain the same output, and so draws more current than usual.
No savings here Iam afraid, it just pulls more current, you cannot break Ohms law.
Payback in just 2.5 years, .....Only in your dreams mate!! I did have to laugh at the laptop you quoted, ...that'll really save you some money over the course of a year!!
@E54,
The thing is E54 you don't save anything at all with electronics that have SM regulators in (post #9), ie. laptops, TV's or anything else similar for that matter, I would be doubtful if certain LED lights (the ones with electronic drivers) would save anything in this context (except the savings you would normally get anyway).
I still don't see where you make any savings at all with this unit.
Actually you may save a little on normal incandescent lamps, but that is about it, because even CCFL energy saving lamps, if they work at all at the lower voltage, have the electronics built into these as well.
@E54,
Agreed, on the electronic SM regulators etc... The are two basic problems with these Vphase units to my mind, one is any straight resistive heating elements will take exactly the same amount of power, but with prolonged time periods, not good when your gasping for a cup of tea, or in my case coffee!! ...lol!!!
The other thing, and probably more important, is that these units are just not of a suitable rating to make much of a difference in cutting energy costs. All the larger appliances where you would like to see a reduction in running costs, will be excluded from this unit...
Even having tungsten or halogen lighting circuits running through these gizmo's ain't that much of a good idea, as reducing voltage to these lamps, will reduce the light output. Now that sounds daft to me!!!
I have yet to see a good review given to these Vphase units by a recognised consumer body, or anyone else come to that. All you tend to get at most, is bland obscure statements of equally non descriptive assumed savings. And that i think is another basic problem, virtually all claimed savings by this company, are totally based on too many assumptions.
shall we all pitch in to make a energy saving device that does work? could be rich and we could retire. we should go back to using candles or just sit in the dark without the tv on
Reply to Vphase units in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
