Vphase units | Page 6 | on ElectriciansForums
Discuss Vphase units in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’ll be honest, if someone offered one on a trial basis, I’d happily give it a whirl. If nothing else it would set my mind at rest. But how do you set up a definable test procedure in a domestic property?
A company I used to deal with have had a 400KVA unit fitted. They weren’t happy when I said all they needed to do was turn the 11/.44KV off load tap changer down 2.5%. In the foundry I dropped the voltage to one plant after we had trouble with voltage regulation at the weekend toasting VSD units.
With domestic supplies the distribution transformers aren’t fitted with tap changers. But the 33/11KV grid units have on load tap changers, it’s just a case of entering a new base value. But that would reduce demand and therefore profits.
Brussels will not be happy until we’re down to 380V. I’ve worked on a plant that had two systems 433V and 380V what a cock up but the manufacturers of the printing machines would not guarantee the gear at the higher voltage.
The first plants I first worked in were all 550V. I helped put in the first of these weird 440V transformer things, after that it degenerated in to bedlam. As plants spread out the distribution systems over lapped. All 550V transformers had reverse phase rotation (a hangover from our own power station) then some loony decided new 440V transformers should have forward rotation. To totally confuse the situation I installed 5off 11/.44KV transformers in a plant that was mainly 550V, the powers that be decided the phase rotations should match.
So we had:
550V reverse
440V forward
440V reverse
I miss the place like I miss toothache!
If it's any help,I've had a VPhase installed for the last 6 months - I didn't pay for it as such- was installed 'free' as part of a PV install.
Installation – It was possible on existing CU only because there was space andCU is a recent 16th/17th edition upgrade with several RCBOs. It was necessary to make a 3rd break in busbar so that the VPhase supplies the RCD block (upstairs and down stairs rings)and a block of mixed RCBOs (kitchen sockets, bathroom lights) and the non-RCD(smokes, downstairs lights), with the third (unregulated) block (most RCBOs)consisting of shed, oven/hob, PV and the feed to the VPhase.
The installation instructions for the VPhase state that it should not be usedto control any thermostatically controlled heavy heating loads (e.g. electriccookers, immersion heater, electric shower) and no heavy machine tool loads(presumably no big motors because of in rush currents?).
Out of the 40+ CUs I've seen in the last 4 months (when doing PV installations)there have only been 2 that would have allowed a fairly straight forwardinstallation.
Operation:
The spec says that the VPhase can regulate up to 20amps on a short termbasis, but I've never seen 4kW on mine before it bypasses. Practically, thismeans that any 2 high loads (e.g. steam iron + kettle) will send it temporarilyinto bypass. The VPhase is meant to be able to regulate at 8amps continuously(above this it gets too hot and goes into bypass). This seems about correct -on my unit it can regulate a 1.5kW load continuously, at 2kW after about 1 hourthe case temperature is 45+ degrees and the unit goes into bypass for about 10minutes then regulates again for about 40 minutes etc.
Losses in unit:
The spec says the VPhase losses are less than 1%. On my unit at a 2kWregulated load, the unit is consuming about 25W, so this seems about correct.However, it looks like it has a base consumption of about 10W-15W, so even atnight when the 'background' load is about 40W, the VPhase is consuming 25% ofthis.
Energy savings:
Equipment with universal electric motors in(vacuum cleaner, food processor, fridge etc) really do show reduced consumptionin the order of 18-20% (mains at 238-242V vs regulated 219-220V from VPhase).However, that's not the whole story. It's evident (change in pitch when switchbetween the 220 and 240) that the motors are running slower. It doesn't make much difference to how wellthe vacuum cleaner works, but although 'instantaneously' when the fridge/freezermotor is running it shows a 19% improvement, if I monitor the consumption overa week on 220V then on 240V the lower voltage only results in a 5% saving.Presumably because the fridge motor needs to do a certain amount of workcompressing the refrigerant and just runs for longer when the voltage isreduced.
As has been previously said, it makes no difference to any thermostaticallycontrolled heaters, they just run longer, i.e. takes exactlythe same number of Wattsxtime to boil the kettle or toast the bread. It looksthough like the microwave takes about 4% less energy to boil a cup of water at220V (takes a bit longer, but less than 10% longer and power consumption is 15%less).
White goods (dishwasher, washing machine)don't show a significant improvement <5%, I presume because most of energyused is in heating water, which isn't affected by voltage reduction - it's alsodifficult to do a consistent back to back test.
Lights - Most of my lights are LED, and Ican't discern any difference (either in brightness or energy consumption)running at the regulated 220 or 240V but the LEDs' consumption are close to theresolution/sensitivity of my test gear. The few halogens, consume about 15%less but are noticeably dimmer. Interestingly I tried an old (notelectronically regulated) fluorescent strip light and it showed both a 20%consumption improvement and no change in light output.
Electronic goods - Most of the stuff I havehas switch mode PSU (LCD TV, radios, computers, printers etc) and there's onlya very slight improvement running on a regulated 220V certainly less than 5%,seems to be about an average 2%.
Gas boiler - The peak electricity load (CHpump + flue fan) reduced by about 15%, it's possible that the pumps and fansrun longer to compensate, but I couldn't tell.
Conclusion: I've a fairly low electricityconsumption (8kWh per day, house occupied all day), and I make it that theoverall costs are somewhere between -£15 and +£5 (i.e. might cost an extra £5through to saving a maximum of £15), which equates to a maximum possible savingof about 3%. But, for example our lighting consumption is now 10% of that usedcooking, whereas before fitting the LEDs it was nearly the same and the newFridge Freezer uses 1/3 the power of the old one (which was the single biggestconsumer). So I would imagine it's possible if had an older F-F, lots ofhalogen/tungsten or fluorescent lights to see a saving over 5%.
As I’ve said before if someone offers one on trial for free I’d give it a whirl. But I’d be a very sceptical person to convince. The inherent losses are my main concern.
I think Yorkshiremike's analysis sounds well considered and fair. There are minor savings to be had but if you offset these against the fact it goes into bypass after load reaches 8 amps which would make the installation very tricky to get optimum results, the initial capital outlay, the less efficient running of certain appliances such as vacuum cleaners, fridges, lights etc....I can't help thinking it's just not a viable technology in your average domestic environment.
Maybe if you have an eco-house and have spent thousands on 300mm of roof and wall insulation, heat recovery HVAC systems, triple glazing and all that jazz then the VPhase might be justifiable as a final effort to squeeze every little bit of carbon out of your footprint.
If I wasn't on a different continent I'd seriously consider installing on of these in Tony's house. For entertainment value alone it would make it worth while. :)
I think it shows how useless and ineffective this unit is
But what carbon footprint does the manufacture of this unit create.
I don't worry about living carbon free as I keep generating carbon dioxide
What with a web cam feed I think it could be entertaining watching Tony with a sledge hammer
I think he's a softie at heart underneath the hard shell of an exterior lies a warm .........ah who am I trying to kid? He'd probably go at it with his steel toe-capped Doc Martens when his morning cuppa takes 45 seconds longer to make.
VPhase is inferior to both VO4Home and VoltisHome. The two latter units are rated for 60amps and both are one line in, one out so easier to install. Technically, the VO4Home is probably the better but overall, VoltisHome is probably the better choice simply because of size. The VoltisHome unit is far more compact and offers pretty much the same as VO4Home but at around £200 cheaper (though check the prices, they are subject to change).
Reply to Vphase units in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Hi does any one know or fitted ic integrated downlights suitable for rockwool .most say lay over insulation which is your standard glass wool...
