Wago connectors inside light fitting
hi guys
just had my first delivery of wago boxes and pushfit/lever connections. quick question can you use these connectors within a light fitting seperate from the the actual wago enclosure? i cant see why not as the light fiting will be acting as the outer enclosure. mainly want to use for connecting loop in/loop out when the rose has to be removed.
any thoughts??
