H
harry olee
Should these be always housed in a wago cable retaining box if under plaster board?
Discuss wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There is no "MF" mark on wago boxes though?Hi Harry - if you need a maintenance free jb then yes the MF marked Wagobox must be used along with connectors from either their 222 or 773 range. I also use the Ashley J803 which comes in one unit for a fiver. Hope that helps
Ahh, there is if you look closeThere is no "MF" mark on wago boxes though?
I quite like Wagoboxes; use a lot of them. But I do agree that they'd be so much better without the internal dividers that lock the Wagos in place. They make it harder to fit and risk stressing the connection.But seriously, I don't like having the terminals inline with the cable entries - any movement of the cable in the clamp can put tension on the terminals - and there's no option to leave slack for retermination.
I see absolutely no reason why you can't put them in any suitable enclosure. It is a nonsense to suggest they are only MF if installed in one of those flimsy Wago boxes.
No doubting the common sense of this.I see absolutely no reason why you can't put them in any suitable enclosure. It is a nonsense to suggest they are only MF if installed in one of those flimsy Wago boxes.
Heretic! You sound like one of those people who say "Never tried guinness 'cos I don't like it"Awful things those Wago boxes
I agree with you and Kingeri. I use the Line products enclosures, Wiska boxes, other adaptable boxes, and any enclosure I see fit for the purpose.
That's too much like common sense. Maybe if you could find an adaptable box with the magic "MF" stamped on it, it would be fineThe whole MF thing is over the top IMHO, what's wrong with using MF connectors in a suitable enclosure of your choice? I would much rather use say an adaptable box of my choosing, making sure the cables are secured of course. The wagoboxes are too limiting as to their applications.
so will the line "eggs" (50mm diam.).Wago boxes are good as they will fit through down light holes
That MF stamp is a nonsense.That's too much like common sense. Maybe if you could find an adaptable box with the magic "MF" stamped on it, it would be fine
Reply to wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
