wago lighting connectors | Page 2 | on ElectriciansForums
Discuss wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I agree but to me it is not the enclosure which is MF. How do you go about fitted half a dozen cables into one.
If i had a situation where six separate cables were joined,i would not want it "MF",preferring to choose a better method,and making it accessible.
.....Or....one i viewed during a recent rip-out,where an enterprising spark,had thrust four joined T&E cables,into a fresh,halved 350ml tube of silicone sealant,and zip-tied it to the studding.
It looked like a fused stick of gelignite...
The whole MF thing is over the top IMHO, what's wrong with using MF connectors in a suitable enclosure of your choice? I would much rather use say an adaptable box of my choosing, making sure the cables are secured of course. The wagoboxes are too limiting as to their applications.
That's too much like common sense. Maybe if you could find an adaptable box with the magic "MF" stamped on it, it would be fine ;)
Reply to wago lighting connectors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
The repair kit is actually sold by WAGO for that specific purpose (in the wall repair). I had wondered myself about shrinking individually first...
