daiplayer
What they like ? ...any opinions on better conectors ?
I agree, apparently they are better now! Hmmmm.
Screwits.....surely they cant be advocating the use of these now.....they're off of the 30's!:crazy:
I shall be topping up my Wago stock from the Elexshow tomorrow!
Not really, No!! Your still quoting the ''Man From Del Monte'' He and his company can class the wago's and the boxes ''maintenance free'' all they want, ...It still doesn't make them officially classified as Maintenance Free. That can only come from an official body like the IET etc... The sooner they get these connectors officially classified the better, everyone will then know, what they can be used for and what they can't!!!
I still wouldn't use them in CU up-grades/changes to extend existing cables. They would look the pits and not professional looking at all. Crimped and coloured heat shrink connections every time in that and similar situations....
Agree about appearance of crimps, but I'm a big fan of Wagos eg for joining the neutrals in a switch![]()
Taught by a lecturer who hasn't the experience, or is biased for some reason!!
You hear the same crap on here too, many times over. The fact is, when you use a good ratchet crimp tool, that will deform the solid core within a good quality butt ferrule, (or any other type of crimp ferrule come to that) then you will always get a sound maintenance free joint/connection.
They are NOT your standard Wago connectors are they?? these are the made for purpose wago din rail mounted connectors...
They are standard Wago 3 pole 41A connectors mounted in a special DIN Rail carrier. 30p each, cheap as chips :ihih:
I dont mean to sound pedantic but I believe you will find that's in fact cheaper than chips. Here to help.David.I have had no problems with either push fit halicons or wagos.They are standard Wago 3 pole 41A connectors mounted in a special DIN Rail carrier. 30p each, cheap as chips :ihih:
Oh yes, I apologise. I was trying to tie the words "do" and "not" together with a screwit (tm) and it must have snapped the apostrophe clean off. Wretched things!From one pedant to another... Your 'dont' is missing an apostrophe :nono::tongue3:
Wago 2 pole get for 10p each and 4 pole 11p each delivered.
When you need to loop in/out in the back box they are a life saver.
Also extending lighting circuits, wagos and a choc box, easy
