Wago's , junction boxes and choc blocks whats best with downlighters | Page 2 | on ElectriciansForums
Discuss Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
fire hoods stink! seriously if the fire hood ever had to be utilised for what it is then the flames must be licking the ceiling and the house is a gonner any way!!
i just fir fire rated lights! simples!
Fire hoods where a great money spinner for a time. The fear around not using them against the truth of how they really work in real life !
find the joists, chip plaster from under joists and about 1" to each side. fish cable from one joist to another, wire up lights, clip cable to underside of joists, tub of poyfiller, bit of rag to blend to match artex if required, jobs a good'un.
Hi telectrix
yeah...sometimes its the only way. doesn't feel good though.
Last one I did there was a plasterer in on the game too so I was spoilt, I cut 76mm holes in the board with a very nice "ck" holesaw (just big enough to get hand in), either side of joist. Then use an extension bar with an Armeg wood beaver (fnarr fnarr) to drill a hole through joist...unless youre lucky like i was and found the original sparks' set of holes. Then place small battens inside when sparky work is done and screw them in place with black phospate passivated screws sunk just below the surface, replacing the original piece of circle board the hoelsaw cut out..... Looks great and no quick and dirties.
Admittedly it was a well paying job ..... OH! and I had a spread following me !!!
If no spread I guess I would do it as described :))
Just as a thought wouldn't it be best to notch joist and fit a "safe plate" over cable? Then everyone's happy
Reply to Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Thank you, it is always good to hear another suggestion :)
