Discuss Wago’s which ones or ideal in the Electrical Tools and Products area at ElectriciansForums.net
I been on the phone this afternoon and Wago are stopping to production of the 2273 and when the tooling for the 773 breaks those as well and the 2773 will be the push fit option. Max 4mm2 cableNever been able to bring myself to fully trust ideal connectors or anything other than wago - just a personal thing.
2273s are great for their compact form - especially behind busy switch plates.
773s are solid, reliable and cheap.
221s are great to have to hand due to their versatility and, as @timhoward mentions, the 6mm option.
More often than not I'm supplied with choc blocks in my day job and they do what's needed. When working for myself, there will always be a decent selection of wago's to hand and the cost is neither here nor there in comparison to their convenience.
Edit: It's worth mentioning that wago make many other, similar connectors, and all have their place, but a line has to be drawn somewhere in terms of how many different connectors it is practical to carry.
I'd imagine popularity of the 221 was a factor in that decision and that would still provide a 6mm option. I'll miss the compact form of the 2273 - must see how 2773 compares in size.I been on the phone this afternoon and Wago are stopping to production of the 2273 and when the tooling for the 773 breaks those as well and the 2773 will be the push fit option. Max 4mm2 cable
I hadn't actually noticed the change, I'd got a LOT of wago's in stock (so much so, 3 years later I've still not exhausted all of that stock) but have the 2773-103, not got the 2273 version to compare side by side but I've been using it for a few months without realising its different so can't be much in it.I'd imagine popularity of the 221 was a factor in that decision and that would still provide a 6mm option. I'll miss the compact form of the 2273 - must see how 2773 compares in size.
Cancel this...in my Wago fixing tin in the van it's still the 2273-203. In my stores it's 2773-403, so I've not been using them yet. They are a bit biggerI hadn't actually noticed the change, I'd got a LOT of wago's in stock (so much so, 3 years later I've still not exhausted all of that stock) but have the 2773-103, not got the 2273 version to compare side by side but I've been using it for a few months without realising its different so can't be much in it.
Reply to Wago’s which ones or ideal in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
