a couple of weeks ago. still not managed to beat my fein type multi tool i got from netto for one pound fifty yet :D
They arn't a waste of money at all. Using a chaser will give you super neat chases and to the correct depth.
Then you can use your SDS or even a bolster an chisel to cut out the chase. Because its been cut, it drops out with no effort at all.
To be honest I'm going to get one as everytime i've chased with a sds drill it looks like its *******.
Have you used the chaser mentioned above David?
I haven't mate. Have had other Erbuer stuff and its lasted too long when using it on a regulare basis. I did get a 10 inch chop saw and I can't fault that particular item, so its swings and round abouts really i suppose
Well I think i'm gonna have a punt on it, aint got the cash to buy a metabo or a bosch. If it lasts me 12 months then happy days
Hi,
I was given one of the £40 ones that Aldi or Lidl did a couple of years back. Anyway it's been OK so far but TBH I do tend to use it on empty properties due to the dust even with extraction, but you do get nice neat cuts and all to the same depth.
Cheers,
Lofty
I bought the Erauber chaser mentioned here last week for £100 all I can say is make sure you put a hoover on it, we didn't have one on the first day so after 90 seconds the chaser looked 10 years old, not to mention the dust, oh lordy the dust it was pretty bad, anyway does the job ok, its abit scary chasing walls that could have anything hidden in them, once the hoover was attached it has been good, not sure if its going to become our #1 favourite tool but it keeps the plasterer and client happy so must be a good thing.
If u got the cash Milwaukee do a wall chaser, top bits of kit i find the dust is alot easier to withstand if ur outside drinking tea while the apprentice does it,
I have one and love it! Dont even think about using it without a hoover.
I abuse all my tools and this one has survived the test of time!
Cannot recommend it highly enough!
I bought one from SF to cut a 4M trench across a concrete floor, took it slowly worked fine. Except the amount of dust, I had a domestic hoover(other brands available) and part way through, the dust bag burst, massive dust storm. Continued with an old Numatic (Henry style) vacuum, much better results.
I too have purchased the tenner chaser from makro and it does the job. As others have said , hoover is required.
For this bit of kit a tenner is great and even if it only lasts for one job, it's well worth the time you'll save.
Should have bought two or three!:D
Out of all you guys using chasers, is there a particular disc that is better than the rest?
Cheers, Mark.
Bosch and Bosch vacuum as it has better suction/sec than henrys and if chaser plugged into it it operates when chaser is on rather on all time.
Would have got a Hilti but way too much money for occasional use.
I've used the Bosch one quite a bit my old boss had it, really nice and light, great for putting in ega tube or flat conduit capping etc. The only reason I didn't go for it was the fact that it only chases down to 20mm and I usually put in 20mm round conduit so it didn't allow enough depth to get a good skim over the conduit when filling. The Hilti is a lump though lol ebay has some good ex hire ones coming through.
I did think about the limited 20mm depth, but majority of installs will be oval or flat. However if the grinder housing is like the normal pro hand grinder 125mm discs might just fit in.
The Bosch set-up is very good our firm has half a dozen kits. There is one weakness however, the plastic back wheels and aluminium axle on the extractor vac are always coming adrift, we now remove them on each new unit. It does mean you have to lift vac to move it, but that's easier than the alternative, we tried glueing and bolting them on without success.
QUOTE=phil7677;220211]makro 9.99 + the govs levy (VAT) chuffed to bits with it for just over a tenner[/QUOTE]
Link0r Phil my good man :)
Wall Chaser
Electrical Tools and Products
phil_davison,
mattmoo1974,
